Have a brand new pressure tank I bought just as a temporary to be installed outdoors. It sits right next to the well. I ran some tests with it and maybe I have usually set things in the past and ran with them but I currently have the pressure switch set at 30/50, and pressure tank at 28psi (set when empty).
What I notice is pressure holds fine but as I bleed pressure off with the pump off, Pressure will drop to 28psi, then fall to 0 like NOW. I have reasoned that thr bladder will be at the bottom of the tank at 28psi so there is just no more expansive volume? So if I want a little more cushion around cut in, I was thinking to reduce tank pressure to 26psi? I realize this will fill the tank a little faster or different but I have had systems that see a sharp drop in line pressure just before the pump picks it up.
Also, I bought a "low pressure cut out" pressure switch that is supposed to cut the system at 10psi below cut in. I am finding that to be about 5 psi below. It is NOT adjustable or bypass-able. I was really hoping for a good layer of protection here but this seems like a POS. The vendor cannot tell me dick about it, the directions say nothing, etc. Are there any other low pressure cut switches I should consider? I am removing that switch and about to just install a standard switch.
