PVC to copper joint needs sealed
Tdkdpt
So I have this issue under my
Kitchen sink where the new PVC pipe attaching to the old copper stub out is leaking. This is a non-threaded joint so i was a little worried about this when I put it together.
my question is, how do I seal this joint to stop the leaking? Would a PVC glue work? Pipe dope? Etc??
I’ll try to post a pic of the joint in question. Thanks so much!
wwhitney
Berkeley, CA
What is the leftmost PVC fitting in your photo? I'm not aware of a way to make a non-threaded joint directly between copper DWV and Schedule 40 PVC.
Cheers, Wayne
If that is 1-5/8 OD copper (1-1/2 inch copper) I would cut that pipe closer to the wall, and solder on a copper trap adapter.
Your less elegant, but solder free, would be to cut the copper shorter, and use the proper shielded coupler to couple a spigot plastic trap adapter to the copper pipe.
Tuttles Revenge
The easiest way to make that water tight connection is with a shielded rubber coupling. Find one that transitions from Copper to PVC/IPS and replace the bushing inserted into the trap adapter with a small section of PVC pipe. ***as mentioned above by reach4***
