Chad Potter
I'm a plumbing novice. Installing a pool heat pump. Installation manual recommends installation of a pressure check valve for larger pool pumps (which we have); however, no information is supplied re: installation.
Have found installation suggestions via an instruction manual of a different heat pump manufacture.
I'm installing a 5# spring check valve (per detailed recommendations of the other heat pump manufacture). In the instruction manual it states "...check valve must be installed with no bends or reducers between check valve and heater".
I'm attempting to install as recommended in manual / diagram; however, in and out heater ports are not an ideal distance apart. Check valve is too short in length and addition of a coupler results in too long of a length. See photos.
My options (inexperienced as they are):
1) Add 2 90 degree elbows to heater out port to give me more length for both check valve and coupler. This is the best solution that I can come up with. However, this would not jive with the instructions of "no bends or reducers between check valve and heater". I assume adding bends would be better on out port than in port.
2) Find a "short coupler" that will work with my scenario. Online search revealed no luck in finding such an item.
3) Trim coupler with hacksaw. I suppose this could be done, but I'm guessing this is not ideal. Don't know how badly this would compromise the integrity of plumbing.
Any suggestions? Thanks in advance for the help.
Chad
Chad
