Hi all, once again here for some help: can I turn a PVC 90-degree long sweep elbow slightly towards its side?
The problem is the plumbing below my bathroom is not in line with the wall above it. I am replacing some old steel 1.5" drain pipe and when I took the section out it is not perfectly 'vertical.' see photos of the cut out galvanized piping:
For most of my DIY plumbing work everything has been lined up in a plane: perfectly horizontal or perfectly vertical. but to get the pipe into the cavity of the wall I need to angle the long sweep before going straight up.
I'm thinking there are two ways to achieve this 'angle':
(1) Replicate the original bends: turn the long sweep on its 'side' a bit and add 45-degree elbow and angle it a bit
(2) Have the long sweep go straight up and use a 45-degree elbow to get it set back into the wall above
I imagine replicating the original is easiest to do, if 'laying' the long sweep on its side a bit is up to code. are any of the two methods preferable? Any other methods to do this and be up-to-code? thanks.
