PureFlow compression ring failure
Nick Hodapp
Seattle, WA
Hi - My home is plumbed with PEX and Viega PureFlow fittings (the ones with the stainless steel compression rings). Both for potable water, and for our hydronic floor heat.
We noticed a leak at a T fitting that supplies the floor. Close inspection showed the compression ring split and failed.
It was installed about 15 years ago. My concern is whether I should be worried about all of the other fittings I have - should I be worried?
I noticed Viega seems to have a 25 year warranty on PureFlow fittings. Should I pursue that for the cost of repair (I hired it out...).
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Contact Viega (we contact our local Viega rep if there is an issue).
They will typically have you send them the part in question, so that their lab can review/analyze and if they confirm it is a "failure" they will likely reimburse you.
Nick Hodapp
Seattle, WA
Fortunately no damage on this one; it was in the only unfinished space in the house, and was a slow drip. I'm worried about the ones inside my walls.
Here's a photo of the failed ring. It failed at the "inspection hole" (?) that is used to ensure you have the PEX inserted fully.
Id be concerned too never worked with that system. you built this and did repair? wondering if you are paying for repairs or are the plumber
Nick Hodapp
Seattle, WA
This comes off the boiler and feeds the hydronic floor. It was installed in 2005 by Advanced Radiant, which is now out of business. But I personally used the same system to do much of my own DIY potable plumbing in the house. I paid my boiler-maintenance company to come out and fix this as I didn't want to mess with bringing the hyrdonic floor back online.
