Finch85
Good morning. I already have an older Culligan water softener that is on its last leg so I purchased a Fleck 5600SXT 48K softener. It arrived the other day and I'm making preparations for the install. My current supply plumbing is 3/4" Pex. My current softener was plumbed with 3/4" pex connected to the bypass assembly. I would like to use Falcon S.S. flex lines for my new softener just for ease of installation.
Question 1: A 3/4" polypropylene yoke was included with my softener. Am I able to connect a Falcon S.S. FIP connector to poly or does the FIP connector of the Falcon flex line need to be poly as well? I've seen them both ways but it seems the poly FIP connections are harder to find.
https://www.plumbingsupply.com/flexes.html#terms
Also, my current softener's drain line is connected to the adjacent bathroom sink p-trap (dishwasher p-trap). I actually remodeled that bathroom last year and just redid that p-trap when I replaced the vanity and sink. I decided that it had been like that for at least 10 years (previous homeowner) so I kept the drain line connected as they had. I knew this was incorrect but was planning to make it right once I bought a new softener. I've attached some pics to better describe my situation. Would a check valve be feasible to install into the drain line or does it truly need an air gap of some sort? Also, I should mention that this really is the only place for me to drain the softener water as I don't have a nearby floor drain, the laundry room is across the hall, I'm on a slab with newly tiled floors that I don't want to tear up, and I'd have to bore through several ceiling joists to get to the laundry room (no easy access to do so). I guess I could drain outside but the way my yard is sloped, water already collects where I'd be draining the softener outside.
Question 2: What are my options as far as correcting the softener's drain line at the bathroom sink? Per the pics, is there enough room to correct this? There is only a little bit of drain line protruding from the wall into the vanity's space.
I'm sure I'll have a few more questions as this goes on but these are my biggest questions at the moment. Thanks!
