Pumping solution
New Jersey
hi,
The city's water main break on a 12-inch pipe flooded my church's basement. It made me think about my home, a couple of blocks away. I have a true sub-basement with a French drainage system. It has a sump pit with a sump pump and a marine battery backup sump pump. I think that setup is good. I wanted to know what kind of pump would I need in case of a flood of water not caused by the sump pit and the pumps can't keep up and I have two feet of water in the sub-basement. That means I have to pump water out of the sub-basement up a flight of stairs through the garage and up a sloped driveway. That driveway is steep like a flight of stairs and about 15 feet. Is this even doable for a pump? Potentially 50 feet in total with two serious inclines.
Thanks a bunch.
WorthFlorida
Solutions
Orlando, Florida
Do you want a pump as a standby or have one on hand just incase? As far as pumps, look up what you need and most will have specific sheets. You may have to go to the manufacturer web site. Look for Feet of Head. Your home probably is 20' or less. 50' is a four story building.
A basement full of water can be thousands of gallons And will take most the day or two to pump dry.
New Jersey
Thanks just a pump in case. The distance from back of the small sub-basement to the the street is the fifty plus feet. So my understanding is that I am really dealing with 20' of elevation head to deal with. ok it's time to do some research. Thanks again.
Fitter30
Peace valley missouri
Trash pump can be either electric or gasoline. All depends what you want to do and how much money. Trash pumps don't use a float switch most use a 2" hose that can be reduced.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
50' of lift is 50' of head. Converted to pressure the pump needs to be able to make 22 PSI, which is the same as 50' of head.
