Gary Way
This is a conundrum for me. First, the configuration: I have a Gould J5S (1/2 hp) that draws water from a poly tank (300 gal) and pressurizes the house water system via a welltrol bladder tank ( large- 5 or 6 ft tall). The water is gravity fed to the poly tank from a spring via an underground reservoir at a higher elevation. The pump draws water with little or no head pressure.
So here's the problem. I was noticing a delayed cut out to 50 psi on occasion, although it always cuts out eventually. I tapped on the switch when it was at 50 psi and it immediately shut off. To confirm that it was not a coincidence I tried it a few times and it always shut down, so I assumed I had a sticky switch contact, and set out to get a replacement. The factory switch is a nice Hubbell ( made in USA) 30-50 psi, approx 22 years old. After a little looking around in person and on the web, I accepted that because of NAFTA, etc, all switches come from Mexico or China. I bought a Home Depot model with the low pressure cut out feature.
I checked the empty tank pressure and it was right on at 28psi. After installing the switch I purged the lines to the switch and turned it on as directed by holding the lever in the start position. I watched the pressure for a quite a long time and the pressure never got above 45 psi. Please note that before I replaced the switch the pump got up to 50 psi just fine.
I thought that sediment might have clogged the pump nozzle, so I drained the tank and cleaned the pump nozzle with a regulation coat hanger. It didn't seem too bad. A little iron mud was evident, but no obvious blockage. I think the pump may have been on its way to failure and the tapping of the switch may have been a real problem, but not the only problem. So I adjusted the tank to 20 psi, and set the switch to 22psi on and 42 psi off. It works fine, but I lost 8psi from prior to replacing the switch. My question is, should I assume the pump is obsolete and buy a new assembly or is there any tinkering (and parts replacement) I can do to get my water pressure back to 50 psi? Cost is not an issue, but reliability is, so I am inclined to replace the whole thing. It just bothers me that it comes to this after the relatively mundane switch replacement.
