Yar02169
Thanks in advance-
I have a regular, simple system for irrigation only. I have a long standing issue with some silt, and my work around is a filter after the pump, before the zone solenoids and sprinkler heads. For reasons unknown, sometimes when the irrigation is done, the pump continues to run, not turning off via the pressure switch [runs at 36psi, switch set to 40 psi]. I've also had issues occasionally with a pressure drop, in which case the pump turns on and runs, but doesn't build enough pressure to trip the switch (40 PSI).
To solve this, I bought a Pump Start Relay switch. I figure this will let my timer control the turning on/off of the pump, and let the rest of the system be. Now, if I do this, is there a need for the pressure switch and bladder tank, or can I remove them and maybe by a miracle also get the leak that allows the pressure switch to turn on the pump?
I would then have a check-valve, pump, pressure gauge, filter, sprinklers. I have seen it mentioned that a pressure relief may be required. If the system runs at 36 psi, what should the relief valve be set at? Why would I need it anyway, in case of the timer failing, or a zone solenoid failure, or a failed start relay? Unless it would be the last zone solenoid that fails, the pump would just continue to water my lawn, correct?
As I started, thanks in advance.
