Pump pressure
BBrown
Fl
I have replaced my pressure switch with a 40/60 same as was on it bladder tank has 38 lb but pump will not get past 50 lb can someone explain to me why
It sounds like there might be an issue with your pump or system setup. Here are a few things to check:
  1. Pump Capacity: Ensure your pump is capable of reaching 60 psi. If it’s undersized, it won’t achieve the desired pressure.
  2. Pressure Tank: Verify that the tank is properly pressurized and there are no leaks.
  3. Pipe Restrictions: Check for any blockages or restrictions in the piping that could be limiting the pressure.
  4. Pressure Switch Settings: Make sure the pressure switch settings are correctly adjusted for a 40/60 psi operation.
If these checks don’t resolve the issue, it may be best to have a professional inspect the system.
