Pump & Pressure Tank Issue
Ghansham
South America
Hi Guys,
I would really like a little help with my setup.
I have a 0.5 hp pump that is connected to 12L tank with a 30/40 switch (I assume it is 30/40)
The switch and the tank came together, I add a 0.5 HP pump.
The issue I am having, is the pressure builds up to around 30psi and it flickers the pump on and off, when I turn of power, the tank vibrates like a hammering sound.
I have a video but I am not sure If I can upload it.
I would appreciate any help or suggestions from anyone.
Usually there would be a 20 psi difference.
Measure the precharge air pressure for the pressure tank. It should normally be 2 psi below cut-on pressure with a submersible pump, and 4 or 5 psi below for a jet pump. Air precharge should be measured with the water pressure at zero.
This used to work right, but started acting badly, right?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Sounds like the water might be running back to the well. Is the pump a submersible down in the well?
Ghansham
South America
Thanks for your response.
The pre-charge air pressure that came in the tank is 19 psi. So I guess that is 40/20?
I never got it to work.
LLigetfa
NW Ontario, Canada
I am pumping water from 2-450 gal storage tanks. The pump and tank are at the same level.
Is the pump external to the storage tanks and is there a check valve between the pump and the storage tanks? When you turn off the pump, does the pressure drop without any water use?
Ghansham
South America
I meant the water source is 2 - 450gal water tanks, YES its external to the pump. There is a check valve at the inlet of the pump and outlet.
LLigetfa
NW Ontario, Canada
The purpose of the check valve on the pump inlet is to prevent backflow. The pump should always be seeing the pressure. Where is the sense line for the pressure switch connected? Post a picture of the pump and tank showing the connection in between.
Midriller
Galesburg, Mi
Remove check valve on outlet of pump and what is the pressure switch on the pump or tank? What is the distance and pipe size between the two?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah you need a check valve on the suction side of the pump. The sound and drop in pressure is the water from the tank going backwards through that gear type pump.
