its doing it again. has been working fine since i replaced the wire untill yesterday. first time it messed up i restarted the pressure switch and it pumped but it was slower than normal, and since then it has the exact same symptoms as last time. pump will only cut on for a sec and will not turn back on untill around 30secs then will bump on for another sec.
pulled the pump today and i dont see nothing wrong with the wires nowhere this time.
wondering if maybe the pump could be messed up this time, since the last time i seen it work it was building pressure slower.
is there an easy way to test the pump? other than just sticking it in some water and powering it on.
here is link to the old post
https://terrylove.com/forums/index.php?threads/pump-only-staying-on-couple-of-secs-at-a-time.76960/
