Mike Clelland
I have searched extensively in all the forums for help with this as it would appear to be pretty basic but couldn't find clear answers. My basic plan is this:
I will use a jet pump (I have a power source and pump location right near the lake) to draw water from my lake (about 50 feet run, 10 foot rise) then pump it uphill (about 150ft run, 30 foot rise) to my cabin.
My understanding is I don't require a deep well jet pump because I'm only drawing it up probably 10-15 to the pump and the pushing part doesn't matter nearly as much (?), so I'm thinking 3/4 hp shallow well jet pump?
I have a bladder pressure tank, which I thought should go up at the cabin rather than beside the pump? (better for jet pump to be pushing rather than the tank?)
UV light, filters, tiny hot water tank etc. will all be in the cabin.
Foot valve, foot valve sock, ball joint above jet pump for testing/draining purposes. Check valve needed along the way?
Sorry if I'm all over the place here... any help appreciated.
