I can see the benefit of it in tight spots, but 800 degrees seems quite a bit hotter than needed. The solder I use melts at about 450. Anyone using this tool on a regular basis? Have an opinion on it's usefulness?
The Hot Dog 2 is rated at 800°
Celsius (1,470°F), so that's quite a bit hotter than the ~450°F melting point of common lead-free plumbing solder. That said, the flame of a propane torch in air is 1,980°C (3,600°F). A torch using MAPP gas in air is rated at 2,050°C (3,730°F).
So the Hot Dog is cooler than a torch. Actually, this can lead to a greater possibility of overheating because you must apply the heat longer than with a torch. But the cooler heating elements are countered by the fact that it applies the heat all around the circumference of the pipe simultaneously, as opposed to a torch where you must constantly move the torch around the pipe. And sometimes, that's not possible when working in cramped locations.
Yes, I have one. The things are damn expensive, but I was able to pick one up in almost new condition off Ebay for less than half-price. It is quite useful, although it has its own unique challenges. For example, you can clamp it onto the pipe, thus freeing your hands. But then you sometimes have to scramble to stop your soldering and get it unclamped before it "burns" the joint. (Whereas, with a torch, you can immediately move the flame away.) Also with a torch, you can shut off the flame and it's quickly safe. I have a Bernzomatic torch with a hose:
With this, I can shut off the flame and holster the torch nozzle in the metal sleeve on the side of the cylinder carrier. But with the Hot Dog, when you take it off the pipe, you are holding onto something with a red-hot glowing chunk of metal on its end. You can't put that down just anywhere. It makes it tricky when working up on a ladder. And the Hot Dog has no immediate off (on/off is via the plug; I use a portable GFCI as a switch for it). Even after you shut it off, the element will be dangerously hot for a lot longer than the nozzle of a torch.
And it does put out enough radiant energy to scorch wood that is too close to the joint if you don't use a shield. But it's nice not having that open flame in cramped quarters.
In short, it's a nice tool to have in my "arsenal" of tools. It doesn't completely replace a torch, but it does offer some advantages over a torch in certain situations.
