proposed subfloor removal for bathroom remodel
drew53813
California
Next year I am planning on remodeling my entire front bathroom. I would like to take it to the studs and remove the existing subfloor, because I want to replace all the plumbing and opening it up would make life easier. However, my problem is the old subfloor has asbestos linoleum all over it. Should I just leave the existing subfloor intact or should I go through the motions of wetting it, setting up my shop vac, and wearing a hepa mask? The measurements are roughly 6x6, maybe a touch smaller. Thanks- Andrew
Don't be paronoid or give in hysteria. Unless you start "grinding" it up, all you have to do is grab a corner and pull, assuming you REALLY mean that it is a sheet of linoleum.
What you don't want to do is to use power tools to cut it or grind or sand it. Once the molding and wall panels are off, you may be able to cut around the perimeter of the room and pull the subfloor with the stuff attached intact.
Are you sure it has asbestos in it? Linoleum typically does not, but the adhesive could. There are some inexpensive test kits available...you carefully cut out a small sample and mail it in.
Cacher_Chick
Test, Don't Guess!
Asbestos, like lead, is always a concern, but mainly for the people that are working with itover an extended period. Be neat about it and don't contaminate the rest of the house, and there is little to worry about.
Don't underestimate the job you are looking at either. The walls are built on the subfloor, so you will have to put some thought into what you really want to cut, and how you will replace it.​
ShowerDude
Showers
Minnesota
I would first ask if you are going to pull a permit or do the work yourself? a small floor like that could be carefully demo'd... Its likely the adhesive that is the concern... If you have an inspector sniffing around is another story. California is yet another story. ( Insert Hysteria here per HJ)
