Why only 30psi? When I tested my system, I intended to go up to 90psi (50% over working maximum). It held fine at 30 psi, but blew out at 45psi after a couple of minutes -- when a CPVC joint I had only primed, but not cemented, let go. Once that was fixed, the system held at 90psi for a couple of weeks. It was interesting to watch the pressure rise during the day and fall at night (the system was overhead in a Florida attic) as the air in the pipes warmed and cooled. I was going to see if the pressure differential actually obeyed the gas laws, but haven't gotten around to that yet
To answer your question, though, if you're really paranoid about leaks, you can buy or rent very sophisticated "sniffer" leak detectors that depend on a rare gas (usually helium) leaking from the vessel under test. Unfortunately, it doesn't take much of a leak to let helium out -- I don't know if average plumbing, particularly plastic, would contain it or not. I've seen silver-soldered joints in hard copper lines leak helium. Weird stuff. Stick with the Dawn & Windex spritzer test.
