Yeah if you maintain it, there is nothing wrong with a galv tank. However, even people who say they will maintain it, always forget. Airing it up twice a year might work for some, but once a month may not be enough for others. It is all in how the water is being used. The more water being used, the more air goes out with the water, and the sooner the tank will become waterlogged. Just one day of running with a waterlogged tank is about like 5 years of wear on the pump.
And yeah if you have a big enough tank, and you make the irrigation and heat pump demands large enough to use exactly the amount of water that your pump will produce, you can get by fine without a CSV.
We could also be just fine with the horse and buggy, instead of switching to automobiles. But horses need a lot more maintenance and are a lot less convenient.
The idea of the CSV with a bladder tank, or a galv tank and an air maker system, is for people to be able to use water anyway they want, without having to maintain anything. As a pump man, I can tell just by the pressure in my shower if everything is OK. Most people can’t tell there is a problem until it is too late. And most people do not want to do anything to their water system but open a faucet when they want water, and shut the faucet when they are finished using water. With a CSV there is really no need to do any maintenance or thinking about how you use your water system. Just like since you now have a car, you no longer need to feed and maintain horses.
It has been my experience that ANY maintenance left for the homeowner doesn’t get done, the pump burns up, and it is all my fault. Which is exactly the truth, because I should have known to make it a maintenance free system that can be used anyway the homeowner wants. And that is exactly what the CSV does.
