I've recently install a new pump and 2 pressure tanks. The installation is shown in the image.
The pump is a Gould's J5S and the tanks are A.O. Smith's PM26 diaphragm tanks.
At first, I installed only one tank. The pump came adjusted 30/50. I adjusted the pressure in the tank to 28psi. I verified this with 3 different gauges. The tank got waterlogged after just about an hour of use. Either it was waterlogged or the diaphragm collapsed because I could feel it when I stuck my finger into the elbow at the base of the tank.
The supplier tested the tank and replaced it under warranty. They also requested that I bring the pump to be checked, which I did. The pump was OK but they adjusted the switch to 40/60.
I added the second tank at the same time that I got the replacement for the first one. I left the pump set to 40/60 as the tank came pre-charged to 38psi. Now after just about 3 days, one of the tank is waterlogged again. Coincidentally (or not), it was the left tank both time.
So before I call the supplier, I was just wondering whether there's something wrong with my installation.
Any advice on my installation will be greatly appreciated. Thank you.
