I got a SquareD FYG22 pressure switch connected with a booster pump and a pressure tank
I am very familiar with that sort of pressure switches and used them a lot and find that they are all of the same layout .
However this one ( supposed to handel relatively higher pressures then the basic model) I find it difficult to set it up for comfortable usage..
When I tighten the BIG nut to increase the CUT IN pressure setting , it increases the CUT OUT pressure as well even without touching the other small nut of the high pressure setting!!!!!
My target is to have a pressure differential ( Between the High and the Low pressures) of only 15 PSI ( to achiev MINIMUM pressure fluctuation which affests showring etc... ) and it would be ideal for me to have 50/65 or 50/70 settings but that seems to be impossible to achieve with this switch.
I could hardly set the Low to 50PSI but the high now is 80 PSI which is too much for my house . right now the small nut ( the Cut out pressure nut ) is totally LOOSE i.e it is NOT tightened at all YET the high pressure is 80PSI
Any Idea why I have this problem?
Thanks in advance for you all
