Pressure Reducing Valve Necessary?
Vasteve
Winchester VA
Hi Everyone,
I'm preparing to replace my main water valve and I'm considering putting in a pressure reducing valve at the same time. I've tested my pressure a few different times at the hose bib and it seems to usually be around 70-75psi. I bought a Watts LFN45 and was planning to put it in with a gauge on the low pressure side.
If I do install this, it looks like a gauge is the only requirement. I don't think the relief valve is necessary since the supply from the street is usually at 75psi. I also have a relief valve and expansion tank on my water heater. (Code Requirements). Is there anything else I need to consider with this project? Is this overkill or should I just replace the main valve and forget about the PRV? The house is 43 years old and hasn't ever had one installed.
Any feedback or suggestions would be greatly appreciated. Thank you!
