RobertV
Hi folks,
Thanks in advance for your help. I've used the forum before and gotten good advice.
I put together a new system to my cabin recently. Here are the details...
Well is 242' deep.
1hp Tuhorse pump with control box; 10 gpm
Check valves set at 25' above pump, 150' above pump and one at the pressure tank
32 gallon pressure tank, with 28lbs pressure (I set this)
30/50 switch that cuts in at 28 and out at about 49lbs
All parts are brand new.
Problem:
When I fired up the system, it pressurized to 50lbs and shut off normally.
I checked the system by hooking up a hose to the drain at the T and allowed it to drain the tank.
When the pressure gets down to 28lbs, the pressure switch kicks in for a fraction of a second (the contacts briefly touch with an arc flash and then the contacts go back to their resting position)...when this happens, the pressure on the gauge goes to zero.
The pressure switch has the manual start toggle lever on the side, so I can then engage the swich by hand. When I do so, the pump starts up and pressurizes the tank to 50 lbs no problem and then the switch cuts out as expected.
Draining the system again produces the same result. At 28lbs where you'd expect the switch to engage and start the pump, the switch makes contact briefly and stops and the pressure on the gauge goes to zero.
Any ideas? Thanks again in advance.
Well is 242' deep.
Problem:
