Power to well pump, but no water
Seth416
I'm reading 240 volts on multimeter at the well head and pressure switch, but pump does not run. Does this mean it's time to pull the pump, or is there something else to troubleshoot?
Probably.
  1. Did the pump ever work?
  2. How many wires go down the well? ... or is there a control box?
  3. How much current is on the non-green wires going down the well? Use a clamp-around ammeter.
Seth416
Probably.
Yes...an older pump...25+ years
2 wires + ground go down the well.
Reading just over 240v...didn't know if there was something in between box and well that would affect current.
Thanks
Seth416
Probably.
Gonna call in the pros if there is not an obvious next step. Had several people tell me I'm out of luck at this point.
Are you referring to the pressure switch as a box? Because if you have a box after the pressure switch, that would probably be a control box for a 3-wire pump.. The start capacitor replaced might fix it, but a new box would make sense. But if there is a bad start cap, there would usually be a lot of current, and the breaker would usually trip.
In the old days, they did not run a ground wire to the well for a 3-wire pump. They felt that the steel casing made a really good ground.
