jacksmith7
- Messages
- 39
- Reaction score
- 0
- Points
- 6
I'm not sure I understand. The shower vent would continue to run along the ground until it reaches a point (the wall) behind the toilet and then go vertical through the roof. The stub of 2" pipe sticking out of the fitting in this mock-up is just to show the direction the vent is running. The washer will be dry-vented.Nope. The vent for the shower must continue to rise vertically until it is 6" above the flood level rim of the highest fixture served by the horizontal branch. So about 42" before you can go horizontal. You cannot dump the washer into the horizontal being used as the wet vent for the sink and toilet.
I appreciate all the input on this, and I apologize if I seem dense, or have created confusion. Attached is a rough sketch that I hope will better illustrate what I want to do.Arm the sink into the shower vent and you get rid of the "horizontal vent" problem and do not have to roll it up on a 45 unless you want to. The washer CANNOT be "dry vented" above a "wet vented" sink drain. However "I" would connect the shower between the toilet and washer drain, otherwise the "Venturi effect" from the washer drain could siphon the toilet.
Not requiring inspections is not uncommon for many small towns in the midwest.Just curious. Where are you that there are no licensed plumbers and no inspections?
The vent going to the shower drain will run under the slab until it reaches the plumbing wall and then become vertical and go through the roof of the pole barn.
The drain and vent for the lav/washer will run under the slab and become vertical at the plumbing wall. It will then connect to the shower vent 9 feet above the floor. The piping will be plumbed as shown in the inset image borrowed from one of Terry's posts. Would it be better to connect the lav/washer vent downstream of the shower vent?
There are no licensed plumbers in the area where our pole barn is located. No plumbing inspections are required, but we want everything to follow the code.
Thank you for any additional input.
Plumbing and electrical are included with the building permit.Strange, I live in a state where many of the small towns don't have plumbing inspectors but all plumbing, whether it is done by a licensed plumber or by a homeowner still needs a permit and an inspection. You get both by calling your state plumbing board. They will send a state inspector out to give you both the permit and inspection. Many times they will also give you pertinent advice also.
Great point...thank you.Ok, that's pretty normal but you need to call the state inspectors to look at your work. Otherwise, if there is a problem in the future and you don't have a signed off permit, your insurance won't cover the damages.
I doubt the State of Georgia would send someone on a 400 mile round trip to inspect a slab down in Climax. There's plenty of remote areas in this state and surrounding states. Heck of a lot more out west.Strange, I live in a state where many of the small towns don't have plumbing inspectors but all plumbing, whether it is done by a licensed plumber or by a homeowner still needs a permit and an inspection. You get both by calling your state plumbing board. They will send a state inspector out to give you both the permit and inspection. Many times they will also give you pertinent advice also.
