PEX to copper drop elbow for hose bib.
Alex_T
Ontario
Hi everyone, looking for some help in regards to my garage hose bib I am completing.
Last year when we were having an extensive renovation done, I decided it would be a good time to install a hose bib into my garage given that our interior walls were down to studs.
I installed a copper to PEX drop elbow that I guess would be installed upside down (PEX leading down through the framed Wall into our crawlspace, copper leading out wall into garage).
I then had our plumber complete the PEX in the crawl space with a shut off valve and a drain for the line. The drop elbow is now closed within the wall that has now been spray foamed and drywalled, so I do not have access anymore.
For the last year I have left the stub out untouched in the garage and would now like to attach a hose bib. My soldering skills are not the greatest, so I am considering using a shark bite bib. My concern with this is the fact that they seem to spin on the copper once installed.
Is this something I should be concerned with? Does the rest of my setup seem acceptable?
Also, I am not sure if the plumber ever inspected for leaks, and I am a bit concerned now that the one copper-pex connection is buried in the wall. Are these connections usually pretty reliable?
Thanks in advance for the help and advice!
Alex_T
Ontario
Also I should add, I will be installing an anti-siphon vacuum breaker to the faucet. .
A drop ear elbow usually has a FNPT thread. What comes out of the wall now? Is it 0.625 OD, or is it 0.84 OD?
That is called a stub-out.
Make sure that you drain before freeze.
I was looking for a non-frostproof anti-siphon spigot with compression fitting, but I did not find one.
Alex_T
Ontario
My mistake, plumbing is somewhat new to me!
I have the drain immediately after the shutoff valve, downhill from the hose bib inside our heated crawl space.
Any concern for having the spigot rotating due to using a shark bite?
Thanks for all the advice!
I am not a plumber. I would be a bit concerned. Here is a compression type that is not anti-siphon:
In using compression, it takes a fair amount of torque. I think fear of crushing the copper is way overblown, unless your wrenches are very long.
Alex_T
Ontario
Here is how it ended up. Secured hose to garage shelving. Think this should be okay?
