Hi everyone, looking for some help in regards to my garage hose bib I am completing.
Last year when we were having an extensive renovation done, I decided it would be a good time to install a hose bib into my garage given that our interior walls were down to studs.
I installed a copper to PEX drop elbow that I guess would be installed upside down (PEX leading down through the framed Wall into our crawlspace, copper leading out wall into garage).
I then had our plumber complete the PEX in the crawl space with a shut off valve and a drain for the line. The drop elbow is now closed within the wall that has now been spray foamed and drywalled, so I do not have access anymore.
For the last year I have left the stub out untouched in the garage and would now like to attach a hose bib. My soldering skills are not the greatest, so I am considering using a shark bite bib. My concern with this is the fact that they seem to spin on the copper once installed.
Is this something I should be concerned with? Does the rest of my setup seem acceptable?
Also, I am not sure if the plumber ever inspected for leaks, and I am a bit concerned now that the one copper-pex connection is buried in the wall. Are these connections usually pretty reliable?
Thanks in advance for the help and advice!
