Park quick disconnect fittings
petepdx
Portland, OR USA
I've getting close to start putting together all the parts for my little project. Inside will be a 'place holder' for a CSV (couple unions spaced for a future CSV1A, pressure tank, air/water mix tank, and an iron removal Fleck/tank.
Except for the 1" PE pipe from the well that is so nicely inside the concrete floor and the cast brass tank tee on the pressure tank, everything is PVC 40/80 and 304/316 Stainless.
The site will be going through some extensive rebuilding, hence the location of all the above may have to moved out of the way from time to time.
To the question. Has anyone used and has comments on using Park quick disconnect fittings ? I don't want to make it look like I'm plugging any seller but if you put "Park QD fittings -parker" in a Google Images search the first few show them. I've also seen them called SDI fittings.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
I use quick connect fittings like that on small water lines in the plant all the time. They work well except they can accidentally come loose from vibration or if someone steps on it. Unions are the more common way to quick disconnect and less likely to come apart.
petepdx
Portland, OR USA
Was just thinking of using them at the tank head and the Fleck. Outside of that a strong believer in unions, specially if the design is PVC based. One issue is watching out for places solids can get trapped but not really an issue in this use.
-pete
