Jason Kay
Hello. I'm installing a new pedestal sink. The waste pipe has a threaded end (see attached photo). I bought a chrome p-trap assembly and an adapter which fits over the threaded waste pipe. The tail pipe (as pictured) is smaller than the opening in the waste pipe. The adapter fits over the pipe going into the wall with the provided washer/gasket. The pipe going into the wall, while it seems water tight, is able to move back and forth into and out of the wall when pulled. I know this won't occur when the entire drain system is connected, but is it ok as is? Is it ok to have that movement prior to the entire p trap assembly being attached? Do I need a different assembly for a tighter fit? Thank you!!!!
