Not sure what did I mess up here : ( P trap wont drain anymore :(
Imcool
Toronto
The Sink drain broke so I replaced it.
Before sink drain replacement, everything was functioning properly until I disassembled abs piping out and the Rubber join coupler (abs 1 1/2 to copper 1 1/4). After reassembling it, the P trap is not draining correctly, and it only drains when the nut of the Rubber join coupler is kept loose ( Check photo ) .
However, if it is kept loose, it leaks drain water. Previously, the same Rubber coupler/joiner was working fine before I opened it.
Could you kindly suggest a solution for fixing this issue with the current setup?
Alternatively, would it be possible for you to recommend a better replacement or installation method that would prevent this issue from recurring in the future?
Unfortunately, I cannot remove the copper drain pipe as it goes into the basement, and it would be quite inconvenient to replace it at this time. Thank you for your kind assistance.
Imcool
Toronto
You have no vent, so it is easy to explain why it won't drain. Time for a licensed plumbing pro.
why was it working before i changed the broken sink drain then? please check last photo.
" Time for a licensed plumbing pro" reply doesnt help,
Weekend Handyman
Active Member
Nova Scotia
I am not a plumber. Breplum is right about the vent. You could add a mechanical vent if this is allowed in your jurisdiction. Check out this video. You will want to make sure the mechanical vent is as high as possible in the cabinet … by rights, I believe it is supposed to be six inches above the flood level of the fixture, but it has been a while since I have read the associated code. Also, try to be a little neater with the cement … I try yo have my work look neat, even when I am the only guy going to see it.
DAMiller
NC
Just checking, but is the concern with the sink not draining or the P-trap not draining? The trap should retain a certain amount of water.
Weird. Neither bowl will drain, even when both stoppers are out?
When the right bowl is empty, and you put water into the garbage disposal, will the right bowl back up more than 3 inches deep?
Tuttles Revenge
You diagnosed it already! The fact that when you tightened down the rubber clamp all the way it stopped working was the key. That tiny leak was the vent. It allowed just enough air in to break the siphon.
Sometimes when a ptrap is glued up if water is in the bottom the glue will drip down and dry accross the bottom a paper thin barrier, causing a stoppage of sorts or a small passage that can easily catch stuff or slow flow. True about the hose clamp indicating the venting issue though
Sink is improperly vented , but it shouldnt have water in it that just sits for like an hour. it should drain just slower.
Add an AAV for sure, stick around study a bit more and try to learn a little maybe get that reworked under there. I hope too you get around to cleanning up the installation under there .
This and much more is total DIY and most of us on this forum want to help, I think thats what its all about.
Imcool
Toronto
yes, it did that as well but when I removed the frenco it drained well.
so i am adding AAV now.
There is something else wrong too. Bad venting by itself will not cause bad draining.
A drain line belly down the line could maybe cause that.
