The Sink drain broke so I replaced it.
Before sink drain replacement, everything was functioning properly until I disassembled abs piping out and the Rubber join coupler (abs 1 1/2 to copper 1 1/4). After reassembling it, the P trap is not draining correctly, and it only drains when the nut of the Rubber join coupler is kept loose ( Check photo ) .
However, if it is kept loose, it leaks drain water. Previously, the same Rubber coupler/joiner was working fine before I opened it.
Could you kindly suggest a solution for fixing this issue with the current setup?
Alternatively, would it be possible for you to recommend a better replacement or installation method that would prevent this issue from recurring in the future?
Unfortunately, I cannot remove the copper drain pipe as it goes into the basement, and it would be quite inconvenient to replace it at this time. Thank you for your kind assistance.
