Tyler Thomson
So I've been in my place for 4 years now and haven't had a problem until this spring. I've lost all pressure at my hydrant and can't even water my garden.
I'll detail my setup with as much info as possible. I have a drilled well that is pretty deep. I have a single line running into my place and once it enters my home it goes check valve, d square pressure switch, pressure tank, spindown filter, softner system. I have good pressure in my house still.
My hydrant is right ontop of my drilled well. Up until this spring I have had great pressure at it but now when I open the hydrant I get a couple spurts of air then water at a moderate pressure and it drops off to next to nothing within 30 seconds of being ran. If I watch my gauge inside the house after the check valve but before the switch I can watch it drop off to about 10-15 psi. I know the neck of that hydrant must have froze because I had no water at it early in the spring.
Where do I start diagnosing my problem? Is it the pump or simply a problem with the hydrant?
I'm totally new to this and only know as much as I've researched so assume I know nothing.
Thanks in advance for any help.
