Nick in threads, would you use it?
Austin, TX
Hello, wanted to get the group advice on this brass Flashshield+ 1/2" fitting. There's two small nicks I just noticed in the next to last two male threads. I'll be attaching it to a black iron tee 1/2" .
Are these nicks anything to worry about? I usually use 4/5 wraps of Blue monster tape and a bit of Blue Monster PTFE dope to connect. I know it might be hard to tell from the pic but they are very small and seems like the tape/dope would seal?
This is for a propane line that leads to an outside grill.
Thanks for your advice!
RH in Austin
Weekend Handyman
Active Member
Nova Scotia
Not an issue, should be perfectly fine.
I always wonder about pex fittings with minor nicks or scrapes on the barbs. If I buy individual/separately packaged fittings from a big box store they are perfect. When I go to a supply house, fittings are stored bins. It is almost impossible to find a fitting that is in "Perfect" condition. Given pros do not have the time I do to look through the bins and find the best looking fittings, there must be some margin for error ... or nothing get done ... or there would be leaks everywhere. Would be interested to her what the pros have to say on this point.
JohnCT
Still learning..slowly
Northeast
Not a pro but I'm going to speculate a bit.
I suspect a couple of minor defects in the barbs wouldn't be an issue with crimp type PEX, but on expansion PEX (which I believe makes a better connection than crimp all things being equal), I would insist on perfect barbs.
Again, speculation.
John
Weekend Handyman
Active Member
Nova Scotia
Again, speculation.
John
I agree ... that is why I buy 90% of my fittings at the big box stores. However, every now and then there is something they do not carry (in this 1/2' 90 in cc to PEX). In these situations, I try to buy the best of what is at the supply house.
Tuttles Revenge
The sealing surface on tapered threaded fittings are made by the first two threads. The rest is designed for torque and strength. Imperfections in the back teeth may cause the joint to bind up and not come apart later.. more so on steel threads than soft brass threads. You can use a file to smooth out the imperfections if they're larger or the peaks are misshapen.
