Newly Installed Slip fit shower drain leaks
MoonmanH3
Toronto
Hello all,
We are installing an acrylic shower base and I wanted to test fit the drain. I am using this drain: https://www.homedepot.ca/product/pro-connect-abs-shower-drain-white-grid-slipfit/1000117477
It seems like a fairly typical design for 2” drains. There are several versions of this type of drain in the big box store I frequent.
When I assemble everything, it leaks through the interior of the drain (I.e, not the tub seal which is silicon sealed). As well, I believe I have the rubber compression gasket and compression nut oriented properly.
My questions are:
1) how far up does the 2” ABS pipe need to extend into the drain?
2) how much does one need to tighten the collar? As much as possible or just enough to press the compression gasket against the ABS pipe?
3) what are typical mistakes newbies make with the installation of this type of drain?
Thanks in advance,
MoonmanH3
Breplum
Licensed plumbing contractor
San Francisco Bay Area
We ONLY install the brass version of those shower drains. The plastic is crap. The bottom nut often jumps the threads.
We always use a full round installation tool to tighten the top compression nut. Oatey 42239
The pipe needs to be fully to the top of the gasket. Have never had one leak in 46 years.
Sorry you are having trouble but maybe a blessing to have an opportunity to use brass before it is later in the game.
