Hi, I've been reading through the forum and understand there are numerous threads about setting up a water storage tank but hope y'all can tolerate another one. From what I've read, I think what I need can be done but just looking for reassurance or additional recommendations. Due to financial stress, I am having to figure out how to get an old well running myself. A little background:
Questions
My plan is to keep the existing pump in place to fill the tank from the well and use a float switch in the tank to turn that pump on and off. Will this work? The storage tank cannot be pressurized. Does this mean I need to remove the pressure switch from the pump or is it ok to stay in place? Does anything need to be done to the tank other than the inlet & outlet connections?
Thank you for your assistance!
- well is 30+ years old, has been dormant for 10-12 years and has only a small galvanized pipe coming out of the ground
- the pipe is galvanized, rises about 18" above ground with an elbow then a galvanized check valve and a short length of pipe with an open end
- I used a union to connect the galvanized to PVC and connected a 1hp Harbor Freight shallow well pump (30-50psi) and a 20gal pressure tank (set to 28psi)
- have not yet run a line to the "house" yet but installed an outside faucet a few feet away from the pump
- the pump gets to 50psi and shuts off, as expected - btw, the unconnected pvc coming out of the ground in the pic is the original water supply to a house that was torn down a decade ago after a fire
- when connecting a 100' hose to the faucet, water runs for about 3 minutes then the pressure drops to 10psi and pump comes on
Questions
