aceinc
I am "designing" my new well system. I live in S. Florida and have a 180' well. The water contains Hydrogen Sulfide gas. Currently we off-gas using no pressure aeration tanks. A second pump takes the water from the aeration tanks and pressurizes it for use in my home.
The first area I would like to address are my pumps.
I currently have a 3/4 HP pump (non-submersible) to pull the water out of the ground. The well is only capable of approximately 2-3 GPM.
The pressure pump is 1.5 HP and pressurizes a relatively new 85 gallon pressure tank.
Both pumps are at least 10 years old but working well. My goal is 10-12 GPM at 60 PSI into the filter system. There are other considerations, however. One is energy efficiency and the other is energy surge. Being in S Florida we get the occasional hurricane that knocks out power. When running off of a generator the surge amperage when both pumps fire up at the same time is substantial and can cause issues.
So the questions in my mind include;
- Are my pumps sized correctly for the task?
- Are there any pumps which do not have the start surge of a traditional pump that will work in my environment? My swimming pool pump motor starts slowly with no surge, for example.
- What are the most energy efficient pumps available? (Within reason price wise)
