New home build... under slab advise.
Runnin4
In the woods, MO
Hi,
I'm working on a new home build... this a Ranch style home and all plumbing is under slab going to a septic.
Here are multiple angles of each area. The main drain is 4", all other smaller lines are 2".
I don't believe I'm missing anything, vent placements and distances, combos, wye's, and so on. I just wanted to throw all this up on here to see if there were any ideas or changes I should make.
Starting with the closest area to the septic line:
Guest Bath 1 - Shower, Toliet, Lav
This is a Laundry area, Washer and Floor Drain
Master Bath: Dual Lavs (can't connect in the app for some reason so it's just showing 1), Toilet, Bath, Shower
continues to next post...
Runnin4
In the woods, MO
Kitchen & Pantry: Kitchen Sink, Pantry Sink, Floor Drain
Guest Bath 2 & Hydro Room: Bath- Lav., Toilet, Shower. Hydro- Sink, Floor Drain
Thanks for looking through this, great info and advise on this forum. I tried to absorb as much as I could before designing but I'm not sure if I over-complicated anything with the venting and structuring. Thanks again!
Runnin4
In the woods, MO
Hi, neither code actually... there's no codes, inspections, anything out here in the middle of the woods miles from a living soul. Thanks for the PDF on the venting!
