New Guest Bathroom
pinter
Tennessee
Hi,
I'm moving a laundry room and installing a guest bath on a first floor. I can't drain or vent behind the toilet without pushing the wall out some 8-10 inches where I really don't have the room to lose.
I want to vent through a shared wall but I'm not sure this is OK. I attached a sketch. The back wall is over the house foundation, and both rooms are in a breezeway addition over a crawlspace. The sub-flooring is all new and I still have easy access below. The floor drain is optional, I was going to add one to the laundry area while I'm at it.
The framing is ready to go as soon as I have a plumbing plan. I would appreciate any help.
Thanks.
Cacher_Chick
Test, Don't Guess!
A washer trap goes above the floor. Every fixture/trap must have a vent. No vent can be horizontal until it reaches a point at least 42" above the floor.
pinter
Tennessee
OK, move the washer vent to intersect with the sink vent at least 42" from the floor.
Can the washer wye into the 2" vertical?
Cacher_Chick
Test, Don't Guess!
Maybe I am looking at your drawing wrong, but a trap's vent is always placed in it's trap arm, which is downstream of the trap.
pinter
Tennessee
Yeah, you're right. Not sure what I was thinking. Install the P-trap at (5), then can I run into the vertical without a dedicated vent loop?
I found a table in the UPC that says 2" can run a max of 5 feet horizontal to a vent, 1 1/2" can run 42". Can I remove the vent loop on the sink too? I left it in for now.
Thanks for all your help. Once this is designed I'll post some pics before gluing it up.
Cacher_Chick
Test, Don't Guess!
If it is a laundry sink drain, it should be 2". Only a lavatory drain would be 1-1/2". How about venting the water closet?
pinter
Tennessee
OK, I put WC vent back in place and drains are on their own line again.
The sink is a lav drain, vanity or pedestal in the bathroom.
