Vent pipe in exterior wall - tee/90 bend
patryk
FL
Hi. I am looking to frame my garage and separate laundry/bath area. The plumbing (vent pipe) is inside the concrete block wall. I want to extent a few pipes and hide them in the
new wall framing but not sure which approach is the way to do it.
Can I add a tee with a short 90 so that it bends along the concrete wall and runs horizontally from there through the new stud wall? Or a short 90 is not allowed for horizontal drain?
patryk
FL
short sweep aka vent 90 is fine, only when greater than 6" above flood rim of highest fixture being served
Thank you.
How about adding a vertical stack just parallel to the main vent, so that it hides between studs, and drain the fixtures through that?
Will this work?
yes assuming, as drawn asuming there is nothing else just a vent through roof and drain below floor
