New faucet is really loud
Stevebeans
Boston
Hey everyone, I recently installed a new faucet (bwe waterfall single handle) and noticed it much louder than my previous faucet.
I also installed new inlet valves if that is relevant.
Now when I turn it all the way to hot or cold, the faucet is relatively quiet. However, when I put it to the middle it gets incredibly loud. Not a banging sound. More like a sound of too much pressure trying to come through the lines.
Obviously there is more pressure with two lines feeding water but this is much louder than my last even when I had both lines running.
Is that a defect with the faucet? Any ideas on troubleshooting to see exactly where the sound is coming from?
Thanks for any advice!
Sylvan
Still learning
New York
"Obviously there is more pressure with two lines feeding water but this is much louder than my last even when I had both lines running".
Wrong
You are not getting more pressure YOU ARE GETTING more volume and the supply valves should be globe type so you can throttle them down.
Open both the hot and cold and then close the supply valves until the noise stops
Stevebeans
Boston
Wrong
Well, I said obviously so nobody would make fun of me
Anyway, doesn't a partially closed valve create the thumping sound?
The supply lines can typically pass greater volume than the faucet's restrictor can let through...so, by shutting the supply line down slightly may solve your problem. It's easy enough to try, and no parts or tools required.
