JimmyH
First I want to thank Terry and all on this forum. I've lurked a long time trying to decide which toilet was right for me and finally pulled the trigger on a Drake II 454CEFG, which translates to a 'universal' height elongated bowl with the tornado flush and the coated glaze that they used to call CEFIONTECT. The toilet and tank were made in the USA which surprised and delighted me.
I also have to thank Jamie Love for his excellent sticky post complete with photos, of how to install the toilet. Made it a lot easier. The install, by myself, and a neighbor who is also 70 years old, went well enough. Setting the thing down on the wax ring was a bit of a struggle, but seems to have been successful, as nothing is leaking. Getting the tank level and plumb was a pain in the caboose.
Assuring the '3 points of contact' required me to start, undo it, and start again on 3 separate tries. When I finally got it I'm a hair shy of one of the two forward points, but I'm not tightening it anymore, or redoing it, for fear of cracking the porcelain.
So I turned the feed line on and the thing was filling up very slowly. After awhile I fiddled with the fill valve, a 330, and it popped up and started filling at a normal rate. Upon flushing all was good but I had to manually manipulate the fill valve to get it up to fill speed again.
I also have to manually, obviously with the tank lid removed, manually manipulate the fill valve to shut the flow off. So do I have a bum 330 fill valve, or is there some adjustment, aside from the water level screw, that I can make to correct this ? The supply I purchased from is not open until Monday, so a change out on the valve will have to wait, if that is my only likely option.
Appreciate any help on this I can get.
