New drain location - offset from stub out/old ptrap
Agm413
Bayonne
Hi All,
I am working on getting this new sink installed and the tail piece is about 7-8" away from where the stub out/old ptrap is.
What would be the best way to get this all tied together. Tried a few things but no luck so far.
The current PVC stub out from the old p trap is connected to cast iron.
Thanks for any help!
John Gayewski
Iowa
Cut the pipe. 45 degree solvent cement fitting. Then short piece of pipe, then solvent cement trap adapter, then a tubular trap.
Agm413
Bayonne
Thanks for the tips . I have the old PVC pipe that part of the old p trap cut not but not all the way off the old cast iron stub. Any tips on getting that last bit off?
John Gayewski
Iowa
A hacksaw or sawzall should be easy enough judging by the picture you have posted.
Agm413
Bayonne
Thanks, I did saw off the sticker, but maybe a bit short. How much of a lip do you need for the coupling to be cemented on?
I tried a Fernco coupling between the 45 and the PVC stub, but it was leaking either at the connection or possibly at a spot where the original PVC to cast iron connection has a small chip now...
Here's where I am at now
You can see the small chip at the 5 o clock of the PVC stub
