GMtech
Hi all,
Long time lurker now stumped!
I'm working on my honey due list and yes I have been really bored with all the stay at home and distancing.
I'm replacing the bathtub on the 2nd floor and it is backed up to the master bath tub. I ended up pulling both tubs as there was no room to work and I didn't want to cut holes in the ceiling on the rooms below.
I will be installing a Kohler Villager tub and the specs call for 2-7/8 inch from the tub bottom to the bottom of the tub drain tee.
The floor joist are 12" but there is a 2" tee (master bath shower drain) under the 1 1/2 double waste tee the tubs use. I did find a setup that will lower the double tee a little over an inch but would like more wiggle room, any suggestions?
The master bathtub p-trap was lowered 1 1/4 inch below the elbow, is this up to code or is it ok to do this?
Thanks much!
Thanks much!
