Neocontra14
Hi everyone. I’m in need of some advice. The lead shoulder is flush with the concrete floor. It is out of round. It is 4”.
I have a both a brass flange and a PVC flange (the PVC flange goes into the pipe about 2”).
I Would prefer to use the PVC flange and bolt it down to the concrete, but wasn’t sure how exactly to seal the flange to the concrete/lead, so I was thinking I could put either silicone or plumbers putty under the flange before I screw it in? Would that seal it well enough so that if the toilet ever backed up, it would back up into the toilet bowl and not out through the flange? I want to make sure I make a good seal.
Or plan b I could use the brass flange and try melting the lead myself (i would have to get more lead).
Unfortunately I’m not in a position right now to cover the cost of cutting up the slab and replacing the concrete and flooring to remove and replace the lead.
thanks for any advice and I am open to ideas and suggestions.
