Need help with Grohmix disassembly
notanerd
Georgia
Have a really old Grohmix that needs its cartridge replaced (picture 1). Grohe support thinks is a 34 434 so they sent me the instructions for that even though the handle is not quite the same. I correctly set it to 100, popped the cap off and removed the center screw but it seems stuck on, the actual knob came off but left the plastic temp ring (and button) stuck on (picture 2) Grohe support isn’t sure how to remove this so I can proceed, and after talking to 3 support folks they actually suggested trying here instead. I did spray some wd40 in hoping to free it, and I can snap the knob back on but still no movement on removing the temperature ring. Not sure if there is some pro trick to this or are there is some other instructions that aren’t 34 434 (perhaps predate 34 434) that I should be following? I did search and read most of the grohmix threads but haven't seen anything this old?
GA-Jon
Georgia
View attachment 93064View attachment 93065
GA-Jon
Georgia
notanerd - - I have the same Grohe shower faucet and I am also trying to remove the temperature ring and it will not release. Looking at your pictures, I'd say mine is the same model and era. If you learned a solution for removing the temperature ring will you please share it with me? Thank you, in advance. GA-Jon
TJRAD
Active Member
California
Your acrylic handle fits on the tapered end of the cartridge. it is friction fitted here. Your acrylic handle and that black adapter with temp ring should have remained attached to the handle. At this stage You need to wiggle and pull that adapter/temp ring off so you can get to the lever and continue with disassembly.
Good Luck
