Hobiecatter
I need a plumber that will do a good job at the following:
I have had three "water treatment" guys out and they want me to use their softener and they all contradicted each other on how it should be done.
The plumber I see advertised are all repair guys and slab leaks etc.
I am in Fort Worth TX, you would think there would it would be easy for me to find someone.
Any ideas where or how to look for a good plumber that would do it the way I want it done?
- Install a buried PRV and expansion tank in the garage,
- Install a loop for a water softener from the shut off valve inside the pit just oustide the garage, into the brick, up the garage wall into the attic, across the garage in the attic, then back down to where I want the water softener. - I am going to buy my own softener online. Installing it isn't a problem, just getting the loop to the location I want from the shut off that leads to the house.
- Install a drain line from the softener location up to the attic and to the vent from the utility room.
