Are you saying that the pump produces water for 1.5 seconds, and then cuts off, or the pump does not produce water, or what?
First, be sure the power is on
Start by checking that the well switch located near your pressure tank hasn’t been switched off. Then check the well’s double-pole circuit breaker to see that it hasn’t tripped. If it has, reset it. A breaker that keeps tripping likely means a problem with the well pump, and you’ll need to call a pro for that.
Then check the pressure switch
(Photo 1) You’ll find the pressure switch mounted on a 1/4-in. tube near the pressure tank. It’s what senses when water pressure has dropped to the point where the pressure tank requires more water. The switch then powers up the well pump.
If the switch is bad, it won’t start the pump and you won’t have water, so testing the switch is your first step. Remove the cover and bang a screwdriver handle sharply against the tube below the switch to jar the electrical contacts. If you see a spark and the pump starts, the pressure switch is the problem. Replace it. A new switch is about $25. If there’s still no spark, you’ll have to replace the controller.
If the switch is bad, replace it
(Photo 2) If you find the pressure switch is bad, test the pressure tank to make sure it isn’t waterlogged (see ‘Problem: Pulsing Water’). To replace the switch, start by removing the wires to the old switch (be sure to label them) and unscrew the switch. Coat the tubing threads with pipe dope or Teflon tape and screw on the new switch so it sits in the same orientation. Then reconnect the wires.
Temporary quick fix
(Photo 3) If banging on the tube under the pressure switch kicked on the pump, it means the contact surfaces of the electrical contacts are pitted or burned, causing a poor connection. You can temporarily restore the surfaces to keep it going until you can buy a replacement switch.
courtesy :
https://www.familyhandyman.com/plum...pump-troubleshooting-and-diy-repair/view-all/
