Kevin Craig
Hi all, I am having a small issue. The back of my 5810 SXT has a sticker that says the BLFC is .125 but the valve came programmed to .5 gpm. I contacted the company I ordered from and they said it's actually a .25 gpm system based on the picture I sent them (attached). I have googled my eyes out and I cannot seem to find any flow restrictors labeled "123" as you can see in the picture. Does anyone know what gpm this restricts to?
I suppose I could manually run a brine fill and see how fast it fills a 5 gallon tub to calculate the old fashioned way, but I was hoping the experts could tell me for sure.
One other question, I have my settings all programmed but I was unsure of the salt lb/cuft. This was set to 9 and my understanding is the higher the setting, the more salt that will be used and the softer the water (less PPM) What is a good setting here? I have a 36k unit, family of four, water is only a 10 on the hardness scale. Not sure what other info is relevant.
TIA for your help.
TIA for your help.
