snowonweb
Recently when the temp outside dropped to 10F, inside my home the temp couldn't get passed 60 while the thermostat was set at 70.
I have a 1952 brick house with plank and 1/4" cement board and 1/4" gypsum board. So there is really no 2x4 wall with space for insulation. Its 1172 square feet ranch with unfinished/unheated basement. House is heated by cast iron baseboards, 135 feet of them. It's 2 bedroom, living room, kitchen and a small office.
Initially it was heated by oil but now I have newly installed Navien NCB 240. professionally installed with navien manifold and taco viridian pumps. There are 2 zones but 2nd zone only runs breezeway's one cast iron radiator.
Initially my navien water temp was set to 140F and the pump was set to delta-t 20F which couldn't keep up with heating up the house. That was my initial setting. Then I lowered the delta on the pump to 10F and that didn't do anything. Then I switched the pump to manual mode and put it on the highest speed (which is 4) and that caused the temp int he house to raise to 63F except that the pump was noisy. If I remember correctly the return water temp was 127F.
Today i finally got fed up with cold house and noisy pump that I set the temperature from 140F to 160F and within 2 hours my home got to 70 degrees. Given that outside temp right now is about 25.
Now I am lost. I mean I am happy its warm but something tells me 160 is not right.
I am located in Connecticut btw.
BTW. Initially I had oil furnace that ran the water at 180 degrees and besides buying 200 gallons of oil every 6 weeks I had no issues with the heat. My issue was with the price of oil.
So my question is what mode should I run the pump and with what settings. Also what temp should I run the water at.
Also I dont know the heat loss calculation of my house but roughly its 100ft x 120ft x 8ft tall walls. I just bought the house and it's my second winter here.
Please advise,
Thank You,
Jack.
These are the links to my hardware.
TACO PUMP
NAVIEN NCB240
BASEBOARDS
Please advise,
Thank You,
Jack.
TACO PUMP
NAVIEN NCB240
BASEBOARDS
