Chris O'Neill
Hello I currently have a Richmond 40 gal gas water heater that I put in 13 years ago this month
Well water with softener
this morning I woke up and could hear a drip drip drip coming from the utility closet. I had about 2 inches of water in my hot water heater drain pan and water was dripping from the T&P (top of heater with copper tube running down towards pan) I pulled the TMP lever up and then back down and rotated it around a little bit and the drip stopped
I will say I have probably only drained it three or four times in the 13 years and I have never replaced the anode rod. I do not have a thermal expansion tank Should I just go ahead and replace the hot water heater? Need to add the expansion tank?
i’m not exactly sure when the water came out it was cold to the touch so it either happened the evening before or overnight never heard it do it just heard the drip
