Most reliable rough-in shower valve?
Hories
Maryland
Getting ready to have a bathroom remodel and was wondering if there was one shower valve brand more reliable than others?
Sylvan
Still learning
New York
Delta Multi choice
Sylvan
Picture added below by Terry
The Delta valve body has many choices for trims.
Sylvan
Still learning
New York
Yikes
I never installed a Delta shower body that did not have integral stops
Why have to use either tile stops or shut the riser or water main to repair the shower ?
Delta Faucet R10000-UNWSHF MultiChoice Universal Shower Valve Body for Shower Faucet Trim Kits (with Screwdriver Stops)
Jo Sui
Alpharetta, Georgia
Does the valve only fit Delta trim? I got a Danze trim set and want to use it for my show remodel. Since I'm not going to changing the plumbing, I want to see if I can still use the old valve. The shower is like 30 years old. Should I forget about the Danze and just go get a whole set including the valve?
Terry H
Alabama
I would replace. I have seen some that are interchangeable but it’s not by design rather by mistake. You will be happier just buying new one. Delta had a lifetime finish warranty if you wanted to check into that but I’d get all new everything if it’s in the budget.
Jo Sui
Alpharetta, Georgia
Thank you. Will do that and get a new set.
I need to replace the roman bath faucets too. Got a set of faucets trim only. (I should've done more researches before I made the purchase.)
The tile guy will open the side of the tub so all the pipes will be very accessible. Most faucets I saw at HD or Lowes don't come with valves. Should I buy a generic valve too just to be safe? I
Terry H
Alabama
I would recommend going to a supply house showroom if you have one nearby. They can get you exactly what you need and want.
The delta shower valve is r10000 and has several connections types like copper pex make etc. it will fit anything you’re probably wanting unless you need a diverted for a sprayer or rain head. And when I say fit anything I mean deltas trim selection. Even their thermostatic cartridge.
The valve for the Roman tub will pretty much follow those same guidelines although not quite.
