Moen Late 70's Shower Valve
RbobD
Seattle, WA
My Moen shower valve cartridge seems to be failing. The water changes temperature (gets colder) on its own but there is plenty of hot water in the sink. I removed the escutcheon plate and there are what appears to be shut-offs for the hot and cold water, which is good because it's a multi-unit building without shut-offs for each unit. I tried turning the slotted stem with a screw driver but ut didn't budge. Do I just need a bigger screw driver and a stronger turn?
Does this likely take the 1225 cartridge?
I've attached photos. Thanks for any help!
Breplum
Licensed plumbing contractor
San Francisco Bay Area
yes, 1225. but your symptom of temp drift is unrelated. changing cartridge can help with drips or ease of pull only, unless there might be some debris trapped in the cartridge
GReynolds929
Active Member
WA
I have found that 1200/1225 cartridges can be prone to allowing crossover as they age.
